RC7: "Quick find" doesn't work in Filmstrip layout
Dreamer
Post by Dreamer »
E.g. if you press "D" to go to Dreamer.jpg file :wink:
It works good in other layouts.
Not really important for me, since I don't use Filmstrip layouts...
XnView 1.80 <x>
Lesmo16
Re: RC7: "Quick find" doesn't work in Filmstrip la
Post by Lesmo16 »
Dreamer wrote:E.g. if you press "D" to go to Dreamer.jpg file :wink:
Wow - I didn't know about that special search / navigation mode! :o
Thanks Dreamer!
Really important for me, since I use Filmstrip layouts for 95% ...
So it should be declared as bug.
Everyone who believes in telekinesis, raise my hand!
ckit
Post by ckit »
Confirmed for both filmstrip layouts.
Dreamer
Post by Dreamer »
Not fixed.
Dreamer
marsh
Post by marsh »
Quickfinding the letter d works for me in all layouts. It just seeks out the first letter of a file in the file-list.
Typing the letter "f" brings up preview-fullscreen view, so quickfind doesn't work with the letter "f".
Dreamer
Post by Dreamer »
marsh wrote:Typing the letter "f" brings up preview-fullscreen view, so quickfind doesn't work with the letter "f".
Yes, "f" key to go to fullscreen should be disabled in browser only (there is still F11 key for fullscreen).
ckv
Post by ckv »
Excuse me, but why there are such shortcuts as 'f' in the first place?
F1 - F12 are OK, but one key shortcut in letters??? :?
I sure hope that this 'f' is the only one.
Lesmo16
Post by Lesmo16 »
marsh wrote:Quickfinding the letter d works for me in all layouts.
:shock: You've got a special version?
Like for others, it doesn't work for me in Filmstrip layout!
Lesmo16
Post by Lesmo16 »
Dreamer wrote:Yes, "f" key to go to fullscreen should be disabled in browser only (there is still F11 key for fullscreen).
Support!
Dreamer
Post by Dreamer »
ckv wrote:Excuse me, but why there are such shortcuts as 'f' in the first place?
There is also: "Show Mask ... M" and "Information ... I" - but only in Viewer/FS - here, such 'shortcuts' or hotkeys might be useful...
Support!
Ok, i remove it
marsh
Post by marsh »
Quickfinding does not work only with thumbnails within layout #6, #7. It works with the other views on layouts #6,#7. 1.80PR. I missed that the first time.
Lesmo16
Post by Lesmo16 »
marsh, I've re-checked it - you're right of course! :)
Dreamer
Post by Dreamer »
Not fixed in 1.80 final.
Hacker
Post by Hacker »
Not fixed in 1.80.1.
On a sidenote, when there are files
aa.jpg <-- cursor here
and I press "a", cursor jumps to "ab.jpg", even though "aa.jpg" matches the "a" I typed.
Roman
