GLIBCXX_3.4.14 error in v0.50
ghetty
Post by ghetty »
root@hostname:/opt/XnView# ./xnview.sh (same with ./XnView)
/opt/XnView/XnView: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.14' not found (required by /opt/XnView/XnView)
Neither the deb nor the tgz works for this reason. I'm in debian squeeze 32bit and apparently have gcc v4.3.5-4, 4.4.5-1, & 4.4.5-8 installed. Any chance it can be fixed. 0.39 worked great but now I'm having trouble even getting that to start.
ghetty
Re: GLIBCXX_3.4.14 error in v0.50
Post by ghetty »
Thank You Thank You Thank You. The deb works perfect now. Merci beaucoup
