Am afraid this is a kind of a newbie questionL whilst being in the browser mode, with left the tree and right the thumbnails, I want to increase the thumbnail-view, so I can see what the thumbnails are about/are showing.
Then I might select a series of thumbnails (often screencaptures) and rename them.
I am missing a slider so as to easily increase the view.
Any suggestions on that ?
TIA
Slider to increase thumbnail view
- Forum Librarian
Re: Slider to increase thumbnail view
XnView MP has this feature, though.xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=51147#p51147]Slider for size of Thumbnails?[/url]) wrote:Yes, but currently i have a problem with the listview control for that...raducoc wrote:Personally I think is more useful and handle to have a slider to free select the size of the Thumbnail into the right of the "View As" icon from the "Small Toolbar" instead to go to the View-Thumbnail size and after that select from there a standard size. Or maybe Ctrl+Mouse whell Up-Down, change dinamically the size of the tumbnails when the mouse is focused into the explorer files window.
mrwul
Thanks.
Meanwhile, sofar I did not look at XnView MP. Frankly, I am afraid I cannot find any description either.
I can download the file, but I cannot find info on MP versus 'normal' Xnview.
MP stands for Multiplatform, that I found out alright.
- Forum Librarian
mrwul
Oops! Sorry!
I overlooked that post. I went back to the Xnview home page to check out XnView MP description.
Anyway,thanks again, I''ll check out MP.
- Forum Librarian
No problem (o:
