0.51-0.69: Tree pane / Favorites - null window
harumscarum
Post by harumscarum »
very often Favorites window in Tree pane became null (see image) - http://joxi.ru/rk0-VP3JTJBxBWl6ntU
restart of MP doesnt help - need to close and open Favourites to make them visible again
Re: 0.51: Tree pane / Favorites - null window
You have not that after a crash??
harumscarum
xnview wrote:You have not that after a crash??
no, just sometimes after restart
in 0.61 as well
harumscarum
same problem in 0.69
program restart not help. need to drag it to make floating and than drag agan to pin it back
and no crash?
harumscarum
Re: 0.51-0.69: Tree pane / Favorites - null window
yes. it happens from time to time on program start
on windows from 7 to 8.1update
orbspider
Post by orbspider »
It happens for me when starting Xnview for first time (not when close and restart)
Favorites or Filter (if active when last closed) is blank, so I need to click on another tab and back to Favorites.
With docked panes (as in the pic above) you can try adding Data pane menu to the toolbar and click it twice to get Favorites shortcuts shown.
harumscarum wrote:yes. it happens from time to time on program start
Always???
