Unknown TIFF tag
nickyoung_
Unknown TIFF tag
Post by nickyoung_ »
Hi, I always scanning images with IrfanView (because its batch scan function is very convient) and saved them to *.tif format, next I will used XnView to crop scanned images and saved it again to tif format. When I open it with Gimp for further details editing, I always get Gimp message:
I can still working on it but the popup message is really annoying. There's no problem if I opened it directly from the first tif format saved by IrfanView, can anyone explain to me what it the reason why? Thanks.
Re: unknown tag
nickyoung wrote:Hi, I always scanning images with IrfanView (because its batch scan function is very convient) and saved them to *.tif format, next I will used XnView to crop scanned images and saved it again to tif format. When I open it with Gimp for further details editing, I always get Gimp message:
Ok, i'll check this problem...
nickyoung
Re: unknown tag
Post by nickyoung »
That'd great! Thanks. The problem remains after upgraded to 1.80.
I really like the croping function provided by XnView. Crop the area I want first, do adjustment if necessary , Ctrl-y to elimated unwanted area (while this 2 helpful function and short key is not available from The gimp and Irfanview) and save it.
