1.8PR: Search results - wrong thumbnail size
ckv
Post by ckv »
Search results haves wrong thumbnail size.
reproduce
- switch browser to thumbnail view
- Uncheck 'options / browser' 'launch browser at startup' checkbox (if checked)
- restart XnView & make search
= :bug: Search results haves wrong thumbnail size
The case get even worse with icon or thumbnail & details view
After changing thumbnail size 'right-click browser / thumbnail size' the size changes back to normal.
Olive
Post by Olive »
Sorry I can't reproduce. Search results thumbnails have the same size as when browsing folders.
Not the same, BUT…
:arrow: ckv
- I can't reproduce your bug, BUT when I display a Search result in the Browser,
I get quite truncated thumb-nails at height, like :
————————Image
- I reported already that the first upper rank was truncated in 1.74, but this is much worse here !!! so : Image
Win 98 SE still…
:mrgreen: Kind regards,
ckv
Re: Not the same, BUT…
Post by ckv »
Clo wrote::arrow: ckv
Yeah you are right. The thumbnail size is ok, but the actual thumbnail is truncated.
And Olive what OS you are using? Maybe this is Win9x bug.
98 only---
:) Yes, it seems it's a specific 98 SE bug… Here, ALL ranks are truncated ! I have just shown 2 ranks to reduce the pic here… and save space on my server ;)
EDIT :
a - if you set very large thumbnails (tick that box too in the Options), let's say, W=400 H=500, then the pics smaller than this size are displayed properly in each thumb-nail…
b - Previews are normal, including zooming…
- I found out the first capture I showed to Pierre about this bug, it's dated December, 4th. 2004… Visible here :(
- A little different, since there the first upper rank has the top of the thumb-nails truncated, while the second rank has the bottom truncated…
:mrgreen: KR
I can't reproduce it on win9x :-(
