MOV files will not play automatically on W2k laptop
chzuck
Post by chzuck »
I have XnView installed on my desktop and an old Thinkpad T22 laptop. Desktop is running XP and laptop is running W2kPRO with all the updates and hotfixes. On the desktop when I click on an MOV file, XnView will automatically play the video, while on the laptop it will not. If I click on Open with - Assocaited program it will play the video with VLC Media player, which is the player installed on the laptop. I assume that the desktop computer is using the video player within XnView.
Why won't the laptop do the same? One thing I should mention, Quicktime is not installed on the laptop. Could that be the reason?
Re: MOV files will not play automatically on W2k laptop
Do you have quicktime codec?
chzuck
Post by chzuck »
I have no idea what you are referrring to. I figured the program had all that I needed when I downloaded it. Help me learn, what is quicktime codec and where do I get it and how do I install it?
XnView is image baed not video :) It uses the video codec installed. So you can install Klite codec pack for example...
