I am experimenting with xnview .51 on linux.
1. I modified a photo, saved it and then wanted to restore to the original. Is there a way to do this? I didn't see an undo.
2. When I modify a photo, I like to retain the original as well as the modified version. Some photo managers put a suffix on the photo file name such as: "DSC01843.JPG" becomes "DSC01843.JPG (2)", or if multiple modifications "DSC01843.JPG (3)" or "DSC01843.JPG (4)". Does xnview have a feature to retain multiple version numbers?
Restoring and Retaining original photos
Re: Restoring and Retaining original photos
No if you overwrite the fileralphl wrote:1. I modified a photo, saved it and then wanted to restore to the original. Is there a way to do this? I didn't see an undo.
When you save the file, you can change the name, but it's not automatically...2. When I modify a photo, I like to retain the original as well as the modified version. Some photo managers put a suffix on the photo file name such as: "DSC01843.JPG" becomes "DSC01843.JPG (2)", or if multiple modifications "DSC01843.JPG (3)" or "DSC01843.JPG (4)". Does xnview have a feature to retain multiple version numbers?
JohnFredC
This thread suggests a nice XnView enhancement: Automatic backup copies
The user could specify some options in Settings:
- Backup/Version settings
[x] Backup when saving
- (•) Prompt
( ) Save copy automatically here: [_________________][..]
Name: [###.{Filename With Ext}.bak______________][v][>]
- (•) Prompt
John
