OK I'm about to give up on using Categories at all.
I setup all these Categories and tagged 10k+ of files.
I reprocessed some files and as a result they have moved from <path1>\x.jpg to <path2>\x.jpg. Path names are different lengths so I can't hack into the category.db to fix it.
I'm not going to re-categorize all these files again. I can't find a free sqlite editor that can do batch replace. I feel like I'm wasting my time. Half the time I'm worried category.db will be corrupt and lose all my data gain so I can't open multiple xnviews. 4 Years ago we asked you to store category either in a folder db file, or in IPTC. It's clearly not going to happen. So what now?
Categories.db AGAIN
Re: Categories.db AGAIN
yes it's a problem in XnView, XnViewMP use different database
Do you use 'sqlite browser'?
obelisk
My search for sqlite editors all can read, and edit one cell
But nothing can do replace <path1> to <path2>
That's why I can't fix it.
When will MP be complete replacement for XnView?
Here is an exampleobelisk wrote:My search for sqlite editors all can read, and edit one cell
http://newsgroup.xnview.com/viewtopic.p ... ser#p85799
I don't know yet...When will MP be complete replacement for XnView?
