Shortcut for jpeg images
josedumoretzsohn
How can I create in XNview, if at all, a shortcut (.lnk) to (for instance) a .jpg image, so I can send it as a .lnk file to another folder? If this is not possible at all, I leave this as a suggestion. Thanks for any guidance.
- Forum Librarian
Re: Shortcut for jpeg images
You can access the shell context menu (and the Create Shortcut command) from within XnView's thumbnail panel by right-clicking on a file while holding down the Ctrl key.
Make sure that Show thumbnail for file shortcut (Tools » Options... » Browser » Thumbnails » Appearance) is activated.
josedumoretzsohn
Thank you, very much. I proceeded as you instructed, and there were both the 'create shortcut' command and the dully created shortcuts.
- Forum Librarian
Thanks for reporting back, josedumoretzsohn. Happy MMXIII (o:
