Auto Trim white objects
mrbombay
Post by mrbombay »
We have like more then 5000 pictures to trim around picture.
Does anybody have the right settings for this?
Here you have a difficult example from one picture...
eL_PuSHeR
Re: Trim white objects
Post by eL_PuSHeR »
Do you mean autocrop? ALT-Y
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
DOS386
Post by DOS386 »
COOL :-)
I'm getting best results with Tolerance 21 ... but AutoCrop is not smart ... you have to find out the background color (here white, no problem) and the tolerance (big problem: here 27 is too much already) yourself.
Hmm, I wonder whether the background colour could be determined automatically by XnView.
Auto-colour and Auto-tolerance
If a user applies automatic crop, he/she indicates/knows that there is a surrounding background and an object in the image. Otherwise, triggering auto-crop would not make sense.
Given the above assumption, both colour and tolerance could be determined automatically by XnView inspecting all border points of the image. The auto-colour would be the average out of all colours. And the auto-tolerance would be the tolerance found in the colour values of all border pixels.
Applying auto-crop to an image multiple times with auto-colour and auto-tolerance would end up in a mess. To avoid this, reasonable maximum values might help.
Currently, auto-colour and auto-tolerance in auto-crop are not supported. These are just some first thoughts how this might work. Probably much more thinking and even trial-and-error would be needed to make this really fly.
DOS386
Post by DOS386 »
not really
no problem
This won't work. A few almost invisible dark noise pixels at the border will enforce a high tolerance eating up parts of the valuable image (see above).
Can't reproduce this.
Suggestions: visual batch crop
Content-aware cropping:
Peter Sobot ([url=http://www.petersobot.com/blog/a-use-for-smartphone-photos/]A Use for Smartphone Photos[/url]) wrote:Michael Macias, in a submission to a Codebrawl last November, came up with a brilliantly simple method of content-aware image cropping. By measuring the greyscale entropy of a window as it slides over an image, the highest-interest thumbnail can be determined automatically.
DOS386 wrote:>> And the auto-tolerance would be the tolerance found in the colour values of all border pixels
Hmm, I can't see why this shouldn't work. If you have dark noise pixels at the border, then auto-crop the way it works now is at a loss anyway, even when setting both colour and tolerance values manually, isn' it?
I'm pretty sure that there is a way to automate this and to achieve a good result for images with a background like the ones shown above.
@XnTriq: Thanks for the links. I had a look at the sample pictures of Michael Macias and found the sample results not overwhelming. Yet, I guess the sample pictures were very difficult for automatic cropping. I assume with above sample image (sport shoe) and similar images the results would be reasonable.
helmut wrote:@XnTriq: Thanks for the links. I had a look at the sample pictures of Michael Macias and found the sample results not overwhelming.
Croppola's output of 351044_08.jpg is also disappointing :-|
I'm confident, though, that algorithms for content-aware cropping will eventually be improved.
If the Gamma (Image » Adjust » Brightness/Contrast/Gamma/Balance...) of 351044_08.jpg is decreased, it becomes apparent that the shoe was placed on a turntable. This leads me to the conclusion that all/many of mrbombay's 5K product photos may well have been shot under the same or similar conditions.
Batch-cropping seems to be a viable option in this case.
  • Tools » Batch Processing... » Transformations » Image » Crop
    • X [ 250 ]
      Y [ 150 ]
      Width [ 720 ]
      Height [ 540 ]
