[linux] some bugs
OMOIKANE
[linux] some bugs
Post by OMOIKANE »
1. Program exits sometimes when adding bookmark or using copy to/move to feature.
2. Very BAD bug: open image blabla.blabla.jpg - save as - choose dir - ok. Image will be saved as blabla.jpg
Open another image - blabla.aaaaaaaa.jpg - save as - choose the same as previous dir - ok. Image will be saved as blabla.jpg WITHOUT overwrite warning!
I like xnview but this bugs make it unusable for now, i am using geeqie+gimp for editing.
Debian Stable.
oops66
Re: [linux] some bugs
Post by oops66 »
OMOIKANE wrote: 2. Very BAD bug: open image blabla.blabla.jpg - save as - choose dir - ok. Image will be saved as blabla.jpg
Debian Stable.
About #2: It's not a bug here ... you have to check into Settings\General\File operations\"Confirm to save changes to file" to prevent this "dangerous" behavior.
OMOIKANE
Post by OMOIKANE »
oops66 wrote: About #2: It's not a bug here ... you have to check into Settings\General\File operations\"Confirm to save changes to file" to prevent this "dangerous" behavior.
Confirm... setting is active.
OMOIKANE wrote:1. Program exits sometimes when adding bookmark or using copy to/move to feature.
Do you reproduce it?
uiwuifhirhf
Post by uiwuifhirhf »
Same here on Windows XP as well as Windows 7 (x64). Maybe it would be better to store bookmark information in the sqlite db ?
Cheers, Robert
