Multiple XnView instance working independently
Conan
Post by Conan »
I used ACDSee before.... (boooo :mrgreen: ) but it is too heavy despite my good hardware !! So I change to XnView, it's better :)
But I can't configure it like I want... I only have 2 questions:
1/
How can I have 2 XnView installation working independently : each have proper settings, proper file association, proper cache folders...
So I try to make one classic setup for all users. And I download a ZIP file and I extract files to one folder... But the associations are not working separately! How can I do that ? Like Two different software ?
2/
How can I use only one tab to open pictures from the browser or the windows explorer ??
Thanks :D
Re: Multiple XnView instance working independently
Conan wrote:How can I have 2 XnView installation working independently : each have proper settings, proper file association, proper cache folders...
  1. Create a directory…
    • %ProgramFiles%\XnView\
    … and subdirectories:
    • %ProgramFiles%\XnView\1st\
    • %ProgramFiles%\XnView\2nd\
  2. Download one of the following install packages… … and extract the ZIP archive to both of the two subdirectories.
  3. Use a text editor (e.g. NotePad) to create config files…
    • %ProgramFiles%\XnView\1st\xnview.ini
    • %ProgramFiles%\XnView\2nd\xnview.ini
    … with the following content:
    [Start]
    ParamsSavingMode=1
  4. Create shortcuts:
    • XnView #1 = %ProgramFiles%\XnView\1st\xnview.exe -ini %ProgramFiles%\XnView\1st\xnview.ini
    • XnView #2 = %ProgramFiles%\XnView\2st\xnview.exe -ini %ProgramFiles%\XnView\2st\xnview.ini
8<––––-––––-––––-––––-––––-––––-––––-––––-––––-––––-––––-––––-––––-––––-––––-––––->8
JohnFredC
Post by JohnFredC »
Excellent post!
John
Conan
Post by Conan »
OK, thanks to XnTriq & cday , i'll try this and reply shortly :)
JohnFredC wrote:Excellent post!
Thank you, John (-:
Conan wrote:OK, thanks to XnTriq & cday , i'll try this and reply shortly :)
Please post back to let us know what kind of solution you ended up with, Conan.
Conan
Post by Conan »
Hi! i try it quickly, it seems to work :)
Conan wrote:Hi! i try it quickly, it seems to work :)
Thank you for confirming, Conan. I hope this info will be of use to other users.
