Setting image save quality
orbspider
Post by orbspider »
Am I right in saying that the only place in Xnviewmp for setting JPEG save quality is in the Batch Convert dialogue window, under Format > Settings ?
The window that comes up is called Write Settings.
This sets the vaulues in xnview.ini JPEGQuality= etc
If this is correct, surely it's not in the most obvious place is it? While we DO need to get there from within Batch Convert, I think we also need to get to Write Settings from the main menu, and from Preview tab as these settings affect files saved after enhancements in Preview tab.
thanks alot
Re: Setting image save quality
you have it in view mode File>Formats settings
orbspider
Post by orbspider »
Oh so there is, that's great!
