so i installed the .deb package in ubuntu 12. progress barrs indicated things were installing and i
got a message that it finished. ok. so how do i run the program? it's not in any of my launch menus
and no desktop link appeared. can't seem to find it anywhere.
thanks,
BabaG
how to run mp on ubuntu
oops66
Re: how to run mp on ubuntu
Try in the terminal, or by the "windows key" ...
Should be here:
xnviewCode: Select all
which xnview
/usr/sbin/xnview XnViewMP Linux amd64 -> Debian - MX - antiX
BabaG
thanks, oops66.
tried terminal command but got:
also looked in /usr/sbin and found no xnview.
thanks again,
BabaG
No command 'xnview' found, did you mean:
Command 'vnview' from package 'via-bin' (universe)
Command 'xview' from package 'xloadimage' (universe)
Command 'nview' from package 'nvi' (universe)
Command 'nnview' from package 'nn' (universe)
Command 'xfview' from package 'xfe' (universe)
xnview: command not foundthanks again,
BabaG
oops66
Maybe you can try again from here, with the right MP Linux version 32 or 64bit:
http://www.xnview.com/fr/xnviewmp/
PS: You can also install it from the .tgz file
BabaG
thanks, oops. i'll try those. might be a couple of days before i get the chance. kind of swamped right now.
thanks again,
BabaG
thanks again,
BabaG
BabaG
hey! that worked! thanks.
BabaG
BabaG
oops66
