multi out
obelisk
multi out
Post by obelisk »
Is it possible for 1 script xbs to output 2 files?
ie one command is save, i may make 1 large + 1 small+watermark
Re: multi out
not possible
Re: multi out
With a Windows batch file .bat calling two nconvert scripts, or *nix equivalent?
[Edited]
obelisk
Re: multi out
Post by obelisk »
I can't. I select images in xnview, so there's no way to use batch or nconvert for this.
Re: multi out
You couldn't batch process a folder of images in an Input folder and put the outputs in 'Large' and 'Small + watermark' folders, for example?
Edit:
Or perhaps an AutoHotKey script assigned to a keyboard shortcut to enter the series of keystrokes required to output both?
obelisk
Re: multi out
Post by obelisk »
No, the use case is I have a folder of images. Not all will be processed.
Each image will be processed to watermark on one of the corners. When chosen the image will output to 2 sizes with watermark in one of the corners.
That's why I am actually viewing the images and selecting/tagging to run script.
