The extremely usefully tabbed compare function seems to be broken in the most recent version of xnView. It would be great if this could be fixed
Thanks
Problem with the Compare function
Re: Problem with the Compare function
tabbed compare?? You means XnViewMP?
trican
The problem I'm having is when I use compare (from the tools menu or by shift+c) with multiple selected images. Then I'm leaving "used tabs" ticked and flicking between slightly different processed images at the same zoom level. However, recently when I try to use this feature the pop-up comparison screen doesn't appear and I still need to press escape to regain control of xnview. Oddly I've tried re-installing an old version of xnview (1.97) but I'm now experiencing the problem with it as well (was previously fine). I think it might be something xnview doesnt like with my setup
oops66
Hi, so in this case, ... you can simply rename/delete your xnview.ini file within this xnview version to have a "blank install", and make some news teststrican wrote:Hi,... I think it might be something xnview doesnt like with my setup
trican
aha! deleting the .ini file sorted out my problem. Thanks so much!
