Yes, Ctrl+Shift+0 (Uncoloring) is not working!
Very annoying. Especially because we cannot (re)assign the shortcut. The bug is older than 0.60. But IMHO the time has come to fix it.
m.Th.
m. Th.
m.Th.
Re: Ctrl+Shift+0 (Uncoloring) is not working!
...just to complete myself:
The best solution here, by far, would be to have the possibility to customize the rating / color shortcuts.
This is very important, especially because we use it all day and the standard imposed by almost all other programs is different (eg. 1,2,3,4,5 for rating, 6-9 for coloring etc.)
m. Th.
Ctrl+Shift+1-5 works for you?
m.Th.
Yes, of course.xnview wrote:Ctrl+Shift+1-5 works for you?
m. Th.
m.Th.
...but your reply got me thinking. And I made a small app to test if the shortcut reaches to (any) application layer. And it does not.
Here are the explanations and the "fix": (read: a very disputable design/implementation decision of Windows' IME subsystem)
http://stackoverflow.com/questions/1464 ... dows-vista
http://support.microsoft.com/kb/967893
...however (at least for me) this reiterates the stringent need to have a fully customizable keyboard layout because:
1. There is a standard in rating and culling and it is different than ours: http://blogs.adobe.com/richardcurtis/?p=1835
2. There is a standard in rating and culling and it is faster + easier = better than ours: (see the link above
3. I'm quite reserved how many new users will have the time / patience / willingness to test & dig to see what's really happening with Ctrl+Shift+0 and to disable a part from the Windows' IME engine just for the sake of the XnView (you know - a new, unknown program). IMHO we must make the cost of the adoption smaller not bigger.
m. Th.
