cannot open some pdf files
Mstat
When trying to read some pdf-files I get "Format of the file <...> could not be determined" (the option Display all image files is on.) This happens with pdf files created by Paperport 14; the files can be read by Adobe Reader. Any suggestion?
Re: cannot open some pdf files
you need to install ghostscript x86
Mstat
Ghostscript (gs907w32) is installed (I should have mention it).
could you send me a pdf that can be opened?
Mstat
I'll be happy to send you an example file: but how/where to send it?xnview wrote:could you send me a pdf that can be opened?
contact at xnview dot com
Mstat
File is on its way...xnview wrote:contact at xnview dot com
ok will be fixedMstat wrote:File is on its way...xnview wrote:contact at xnview dot com
Mstat
Great! When it can be expected to be fixed? Thanks,
Mstat
Mstat
i think that next week i'll release it
