BUG: Unable to open .rar from XnView browser...
ghost zero
Post by ghost zero »
BUG: Unable to open a .rar file from XnView browser. When I try nothing happens. As a workaround, I have to manually press F3 to open with associated program. Can this be fixed?
XnView Standard 2.04
Win7 x64
ghost zero
Re: BUG: Unable to open .rar from XnView browser...
can this be fixed soon?
ghost zero
version 2.12 and still a problem...
ghost zero
xnview 2.22
winrar 5.10
all the newest, but still a problem...
ghost zero wrote:BUG: Unable to open a .rar file from XnView browser. ... Can this be fixed?
Not really a bug, rather a format that isn't currently supported...
RAR and ZIP are archive formats as you know rather than image file formats, and although there have been several requests to add support they haven't been added yet. So really a feature request rather than a bug report...
ghost zero
but other non-image files types work correctly. just not the .rar. and the .rar used to work correctly before xnview 2.x.
ghost zero wrote:... the .rar used to work correctly before xnview 2.x.
I am corrected, I thought .rar and .zip support were both long-outstanding requests. :)
do you have the archive addon? it works for me
ghost zero
i haven't installed any addon. but this used to work fine without any addon back in 1.x.
NOTE: i just want xnview to let me open a .rar file with winrar. so winrar should popup externally. currently, nothing happens and i have to press F3 to manually make it happen.
no, xnview had always used rar addon
ghost zero
but i'm not requesting to view the contents of the .rar inside xnview. i just want to be able to open the .rar from xnview, like windows explorer.
oh sorry, do you have changed Options>Keyboard => Open action
ghost zero
xnview wrote:oh sorry, do you have changed Options>Keyboard => Open action
thanks, i just have to change that setting. [options > general > keyboard/mouse > option action (browser) > archives]
but i recommend that setting to be off by default and only auto switch on when the addon is installed. otherwise, it's very confusing to new users--since it does nothing without the addon.
