It brakes the image when doing lossless cropping so that after it's done it can't load it anymore.
Is unsafe if there is no backup of the file, since lossless cropping is done on the file itself.
I've uploaded one of the files causing problems, I want to crop out the other people in that image.
https://mega.co.nz/#!OQ5ygR4Z!c-Heezw8c ... LZuO1jqc3w
Password on pm, it's a private file.
0.61 lossless crop fail
bitz4
MP 0.90 x64, Win 7 64-bit
piXuniverse
Re: 0.61 lossless crop fail
Hmmm i use that feature quite a lot (99% on JPG's), didn't had a problem with it yet, i'll make a backup from now on though
which password?
bitz4
@piXuniverse, lossless works only on jpegs, and I encountered it often on classic but not once since I've been on MP, this is the first time and out of the bunch only two files were affected.
@xnview, Just tried it again on the image I've posted and it worked... crap.
Edit: try to cut from right above her head till bottom and it goes blank, cut including the hammock's wood spreader bar and it works.
