ART file format
oroboros
ART file format
Post by oroboros »
I'm sure this suggestion is going to sound ridiculous, but here goes ...
I am trying to consolidate all my pictures from over the years into one place, and into modern formats. Most of those that need converting I can convert, one way or another, but there is one file format that is nearly impossible to open anymore - the once-dreaded AOL (Johnson Grace) ART file format. It used to be openable with IE, but they dropped support ages ago. As has everyone else.
The only program that I know of that still opens it correctly is called Graphic Workshop Professional, with an added plugin. And that's it, AFAIK.
Anyway, obscure request, but one can hope ... Thanks for listening.
Re: ART file format
Not as ridiculous or obscure as you might think (-:
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=46124#p46124]unviewable photos..[/url]) wrote:
Forum references:
Off-site resources:
oroboros
Re: ART file format
Post by oroboros »
I guess not ...
Thank you so much for the link to an editor other than Graphic Workshop Professional to open these files in. Much appreciated.
m.Th.
Re: ART file format
Post by m.Th. »
oroboros wrote:I guess not ...
btw, why you do not convert them to another format? Eg. png, jpg, jpx, tiff etc.
m. Th.
Drahken
Re: ART file format
Post by Drahken »
oroboros wrote:....
I am trying to consolidate all my pictures from over the years into one place, and into modern formats. .....
^Converting is exactly what he's trying to do, but you can't convert if you can't open.
m.Th.
Re: ART file format
Post by m.Th. »
Drahken wrote:
oroboros wrote:....
Sorry, there is a common mistake in forums to answer without carefully reading the messages before. Now, I am guilty of this. :(
OTOH, he can use ImageMagick (http://www.imagemagick.org/script/formats.php ) which AFIAS opens/convert ART files.
It has the advantage that it is a batch command line tool and he can easily convert his files.
m. Th.
Drahken
Re: ART file format
Post by Drahken »
No, the .art format that imagemagick supports is unrelated to the aol one.
http://www.imagemagick.org/discourse-se ... =3&t=21406
miles_prower
Re: ART file format
Post by miles_prower »
Or you could just do as I did.
1. Hit up OldVersion.com for AOL 8.0 - http://www.oldversion.com/windows/america-online-8-0
(9.0+ embed IE and ditch .ART support)
2. Install it. (use a virtualbox XP VM, please do not install it on an OS that you intend to use).
3. Use it to open and Save As, the images.
Bit of a hassle when you have dozens of images, but it worked.
