Version 1.80.1 ...
I have a file show.sld that contains the following lines:
# Slide Show Sequence
"F:\img1.jpg"
"F:\img2.jpg"
"F:\img3.jpg"
"F:\img4.jpg"
The parameters for timer, effects, etc. are purposely left out because I´d like to use the parameters stored in the xnview.ini file.
The command line syntax:
e:\programs\imaging\xnview\xnview.exe -slide "e:\show.sld"
The slide show starts but it doesn't use the parameters defined in xnview.ini.
Any suggestions? Thanks!
Slide show from command line
Re: Slide show from command line
Right a bug if some settings are missing in the sld file...9Mark9 wrote:Version 1.80.1 ...
"F:\img1.jpg"
"F:\img2.jpg"
"F:\img3.jpg"
"F:\img4.jpg"
