As we can show directories in a sidebar (favorites or directories) I would like the ability to move by dragging and dropping files directly into the directories. I've tested ExifPro and it's possible with this software.
drag and drop move or copy files
lian
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
ralphwillie
Re: drag and drop move or copy files
That is really nice. From where to download the software?
lian
It's a shareware (? not sure about it): http://www.exifpro.com/ -and thumbnails are much clearer than XnViewMP. If you consider only browsing and basic manipulations, it's a very interesting alternative.
Really??lian wrote:thumbnails are much clearer than XnViewMP
lian
You can test ExifPro and you can compare. I tried all thumbnails options in XnViewMP and did not get the same quality.
Something I like very much in ExifPro is the density of thumbnails. Names are shorten and I like it as I rarely need instantly the full name of a file. So there are more thumbnails on one line.
hum, i don't see any difference in thumbnail
lian
Did you test it or did you just took a look at my screenshot ? Well, I suppose it can be the "excitement of the new software". If someone has some time to take a look and give his advice here
you talk about the renderer of thumbnail image?
lian
Yes, about the rendering of the images. There is an option where you can choose the sharpen of the thumbnails.
you have it in XnViewMP toolian wrote:Yes, about the rendering of the images. There is an option where you can choose the sharpen of the thumbnails.
lian
I've got -in french- "utiliser des miniatures de très grande qualité" et "augmenter le détail des vignettes"- but nothing to choose how sharpen they can be.
c'est "augmenter le détail des vignettes"
