2.05: File Sorting by type does not work properly
ozc2k
Post by ozc2k »
I'm using version 2.05 and I'm having all kinds of issues with it sorting files alphabetically and by type.
I'm pretty sure that when I sort files by "type" that .PDF files ought to be together without .FLV or .MPG files mixed in between, above, and below them.
ozc2k
Re: File Sorting Issues
Post by ozc2k »
So no solution or anything?
i'll check
ozc2k wrote:So no solution or anything?
I've tried to reproduce your problem. There is something really going wrong, in my case for example the ZIP files (German: "WinZIP-Datei") and files with unknown filetype ("Unknown") in column "Type" are not listed next to each other. And the order of the entries in column "Type" is anything but alphabetically.
ozc2k
Post by ozc2k »
helmut wrote: "Type" are not listed next to each other. And the order of the entries in column "Type" is anything but alphabetically.
Yeah I noticed the Alphanumeric order is off at times as well.
ozc2k
Re: 2.05: File Sorting by type does not work properly
Post by ozc2k »
So is this going to be resolved in the next update?
ozc2k
Post by ozc2k »
Sigh... It seems when XnView wants to sort files by type they don't mean .jpg or .png.
I am trying to read a manga and chapter 2 is showing up before chapter 1 in the order.
Both chapters are Jpeg, however chapter 2 is Truecolor v1.1 and chapter 1 is 256 Grayscale.
I think that's taking file types a bit tooooooo farrrrrrr.
Can we please get "sort by file types" fixed so the only thing that's seen is jpg, png, etc? Or at least give us an option to dumb it down?
oops66
Post by oops66 »
Hello, ... even with the 2.10 version (or 2.13 now) ?
http://newsgroup.xnview.com/viewtopic.php?f=35&t=29087
____ 2.10 Changelog
Added:
* File sorting - viewtopic.php?f=35&t=28796
ozc2k
Post by ozc2k »
oops66 wrote:Hello, ... even with the 2.10 version (or 2.13 now) ?
Ah I see.
Updated to v2.13...
Yes it's still placing True Color jpegs after Grey Scale jpegs in version 2.13.
Screenshot:
001, 002, and 018 are truecolor, the rest are greyscale jpgs.
I found the problem. It's sorting by "format", not by "type" aka the extension.
Format should be a different option.
