Can i restore default file association?
drugo
Post by drugo »
Hi
i run w7 64bit and the last version of xnview (portable ,the zip file)
well under option system integration ->association -> i clicked windows file association..
and it does associate all the image file to xnview
is there to go back to the default w7 file association?
thanks
Re: can i restore defualt file association?
Uncheck the file association in this dialog
drugo
Post by drugo »
xnview wrote:Uncheck the file association in this dialog
i did it
the list is empty like the screenshot where there is the green arrow
if i click on the red arrow , even in the list there is no item selected , it associates lot's of extensions
drugo wrote: if i click on the red arrow , even in the list there is no item selected , it associates lot's of extensions
Yes i have the bug, i'll release an update...
drugo
Post by drugo »
but seems to be present in 1.99.5 and even in the last 2.05
but now it did mess up all my extension
don't know how fix them
could you add an option to restore to the w7 sp1 64but default ? i would appreciate it alot
do you know registry?
drugo
Post by drugo »
xnview wrote:do you know registry?
yes and?
what should i do?
In HKCU\Software\Microsoft\Windows\currentVersion\Explorer\FileExts, you have for example .bmp\UserChoice (ProgId=XnView.*)
Remove the UserChoice key
drugo
Post by drugo »
xnview wrote:In HKCU\Software\Microsoft\Windows\currentVersion\Explorer\FileExts, you have for example .bmp\UserChoice (ProgId=XnView.*)
thanks i will try it
or can i use a registry finder like RegSeeker ?
BeNiSh
Re: Can i restore default file association?
Post by BeNiSh »
I want do install and uninstall unattend batch script, but I have troubles with restore association after uninstall. I can "manually" associate throught registry after install, but after uninstall isnt restored previous association. this two things are already programed in main app, so is it possible do switches for xnview.exe for this functions (one for association with list of wanted extensions and one for restore association)?
BeNiSh wrote:this two things are already programed in main app, so is it possible do switches for xnview.exe for this functions (one for association with list of wanted extensions and one for restore association)?
Sorry but i don't understand?
drugo
Post by drugo »
there is an update
does it fix it?
does it include a restore to defualt association?
The last update fix the 'windows associations' button, but no standard way to restore
