Perhaps someone knows the answer.
Question: How to change the folder "C:\Users\xxx\Anwendungsdaten\XnView\XnView.db" for all users to "c: \temp\xnview"
Reason: Userprofil is too big
Thanks
Olli
XnViewe db and ini file
Re: XnViewe db and ini file
Option>System integration
will67
Yes all other files will be moved, but the xnview.db is still in user profile and it grows up by working.
I found in Options Systemintegration only the option for the .ini file and other files. The .db is still in the user profile. Ohter file will be set to c:\temp\xnview with category.bak and category.db file.
Idea ??
Olli
Idea ??
Olli
You have 2 settings, one for .db and one for .ini
will67
Yes I have 2 settings, one for .db and one for .ini
the first one is for .ini and the secound for .db but only the category.db will be moved to the folder c:\temp\xnview
If you rename the xnview.db, and start XnView?
will67
Good Morning,
Sorry, No. A new XnView.db wil be create in the user profile.
Olli
Olli
sorry my fault, yes there is no way to set path for XnView.db.
And if you change XnView program location, and use 'XnView'?
will67
Sorry, No. same problem.
do you have tried a hard link "C:\Users\xxx\Anwendungsdaten\XnView" to "c: \temp\xnview"
will67
Good Morning,
Yes, I tried it. Do not work.
Olli
Olli
If you use a hard link, what's happened?will67 wrote:Good Morning,
ozc2k
IMO you should disable caching. It's not necessary. I have folders with thousands of images and it doesn't take that long to generate thumbnails.
I'm not sure about xnview but in the past I've had cached thumbnails for files conflict with other images because it cached the previous files thumbnail and did not detect a change.
Also the less you cache the more secure your personal data is.
Browser>thumbnail>Cache uncheck enable caching
