When I try to convert an image to jpg, xnview crash
This happens only when the image to convert is a png (but file extension is .jpg)
I know this is incorrect but I have 10k images to convert and some have these kind of errors
Crash when converting a specific file
Peter2
Re: Crash when converting a specific file
Can you post an example?
Peter
Peter
If you are able to place the PNGs with a JPG extension into a separate folder, you could then use a batch renaming utility to change the extension of those files from .jpg to .png very easily. Then you should be able to convert the images to JPGs successfully.
Edit:
The XnView browser Tools > Rename... function can be used to change the extensions of a folder of images without altering the file names:
If you can't separate the files with the incorrect extension easily if you upload a sample file maybe Peter2 has an idea?
Edit:
