Option to Suppress "Save Changed File" Messages!
viking
Post by viking »
I often manipulate images in Full-screen View mode (F11; and then rotate image using Shift-L). Thereafter, I want to continue to the next file but without keeping the manipulation (rotation). However, when I try to advance to the next file, I get a message "Do you want to save changes to *.jpg? Save/No/Cancel".
I don't want to save the manipulated file, and I also don't want to keep getting this message. Is there any way to suppress it as in classic xnview? (e.g. an Option in the Settings please)?
I eagerly installed v0.64 hoping that this option had been added, but unfortunately not :( .
(p.s. This issue was discussed in the past, never resolved and the thread steered towards another subject: http://newsgroup.xnview.com/viewtopic.php?f=35&t=28403)
herb
Re: Option to Suppress "Save Changed File" Messages!
Post by herb »
please see also my threadhttp://newsgroup.xnview.com/viewtopic.php?f=60&t=28190.
Unfortunately I did not get an answer to my proposal/request.
Best regards
Herb
budz45
Post by budz45 »
Just disable the option "Confirm to save changes to file" found in Settings>general>file operations
This option has existed for many version now.
Or do you expect XnViewMP to dump all your unsaved changes into system memory??
viking
Post by viking »
budz45 wrote:Just disable the option "Confirm to save changes to file" found in Settings>general>file operations
Thanks :D !
I didn't realize that this option would do what I wanted. I guess that when I saw it a long time ago, I assumed that it would save w/o confirming. This is also what others had stated in the previous thread: http://newsgroup.xnview.com/viewtopic.p ... 03#p112994. However, It simply doesn't save at all when unchecked.
