Search returns no results for three letter terms
When searching the forum for posts containing a three character term such as skf or dxf or jp2 no results are returned...
DOS386
Re: Search returns no results for three letter terms
Known problem of PHPBB forum software.cday wrote:When searching the forum for posts containing a three character term such as skf or dxf or jp2 no results are returned...
- Forum Librarian
[quote="XnTriq (Re: Scanning "film negative" and convert to "positive"?)"]Out of frustration with phpBB I created an OpenSearch plugin for web browsers.[/quote]
… and an alternative method for IE-based browsers.
- Forum Librarian
Re: Search returns no results for three-letter terms
This is due to a limitation in MySQL. The forum's search backend has now been switched from Fulltext mysql to Fulltext native, and the search index has been updated.cday ([url=http://newsgroup.xnview.com/viewtopic.php?p=119711#p119711]Created PDF files are HUGE!!![/url]) wrote:For some reason the phpBB format doesn't return results for three-character strings, which is particularly unfortunate for computing topics where file formats are usually three-characters...mrjacoby1 wrote:... searching for the letters "PDF" returns zero results in this forum
Test: Forum search for keyword “pdf”
- phpBB.com
- newsgroup.XnView.com
Thanks, that should be very useful...XnTriq wrote:This is due to a limitation in MySQL. The forum's search backend has now been switched from Fulltext mysql to Fulltext native, and the search index has been updated.cday wrote:For some reason the phpBB format doesn't return results for three-character strings, which is particularly unfortunate for computing topics where file formats are usually three-characters...mrjacoby1 wrote:... searching for the letters "PDF" returns zero results in this forum
The Forum search facility now supports searches for three-character terms...
