Does FTP works ?
lian
Does FTP works ?
I made a test with sending FTP in Ctrl+U module but it does not work - says it's impossible to connect to FTP domain. I have no problem with WinSCP.
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
Re: Does FTP works ?
i have no problem with my ftp server
lian
OK. A little perturbing. I suppose there is no special authorization for XnViewMP FTP connection ?
if it's possible, send me the ftp settings?lian wrote:OK. A little perturbing. I suppose there is no special authorization for XnViewMP FTP connection ?
lian
OK it works when creating a dedicated user and directory. But if I use main name and password, it won't work.
what's the difference between main & user account??lian wrote:OK it works when creating a dedicated user and directory. But if I use main name and password, it won't work.
lian
The "main" user is the FTP login and password given by the webhoster - it gives access to all the server. The "user" account is an FTP account created with access to only one directory. It works with "user" account but not the main account. I suppose these are not the official terminology but I don't know the real name
