V2.22 Crash in browser when selecting jpg edited by GIMP
Anika
Post by Anika »
Hi Pierre,
I just updated to XnView Classic 2.22 standard. In browser mode XnView crashes when I select a jpg-file that has been saved by GIMP with XMP data. In V2.04 and 1.97 and XnView MP 0.56 these files cause no Problems.
This is how I can repoduce the error:
I open with Gimp 2.8.8 a picture made by a digicam (Nikon D5200 Canon A720 tested) that contains IPTC, EXIF and GPS. I select export with standard settings (Keep Exif, 4:4:4 Quality, with XMP data). This new picture causes a crash.
Example (9,21 KB): http://www.bilder-hochladen.net/files/kgg9-x-182b.jpg
There is no error If I deselect in GIMP save XMP data. This seems to be the problem.
Example (5,65 KB): http://www.bilder-hochladen.net/files/kgg9-y-e369.jpg
I hope this description and examples help to solve the problem.
Greetings,
Anika
This is the windows 7 error log:
Name der fehlerhaften Anwendung: xnview.exe, Version: 2.22.0.0, Zeitstempel: 0x53425475
Name des fehlerhaften Moduls: ntdll.dll, Version: 6.1.7601.18247, Zeitstempel: 0x521ea8e7
Ausnahmecode: 0xc0000374
Fehleroffset: 0x000ce753
ID des fehlerhaften Prozesses: 0x4c0
Startzeit der fehlerhaften Anwendung: 0x01cf5ef1a7509570
Pfad der fehlerhaften Anwendung: C:\Projekte\XnView\xnview.exe
Pfad des fehlerhaften Moduls: C:\WINDOWS\SysWOW64\ntdll.dll
Berichtskennung: 0a9f3777-cae7-11e3-ab15-005056c00001
This is the Information in the error log:
Fehlerbucket , Typ 0
Ereignisname: APPCRASH
Antwort: Nicht verfügbar
CAB-Datei-ID: 0
Problemsignatur:
P1: xnview.exe
P2: 2.22.0.0
P3: 53425475
P4: StackHash_a0e9
P5: 6.1.7601.18247
P6: 521ea8e7
P7: c0000374
P8: 000ce753
P9:
P10:
XnView 2.04, 2.13 Windows 2000 SP4 and Windows XP SP3 and Windows 7 64bit
Re: V2.22 Crash in browser when selecting jpg edited by GIMP
you have a crash with this picture?
in browser?
Anika
Post by Anika »
Yes, with this example and many other pictures like this.
The browser shows the thumbnails with no problem. But it crashes as soon as I select the thumbnail by mouse or arrow keys to see it in the preview area. If the preview area is not visible the selection causes no crash. Even if I drop the file on the xnview.exe to open it directly in view mode there is no problem. There I can flip through the pictures by the picture up and down keys without problems.
So, the preview seems to be the problem.
Happy weekend,
Anika
do you have Addon/Xmp.dll?
stoffel
Post by stoffel »
Same problem here and yes it's the XMP Addon.
I uninstalled and reinstalled full Version but without XMP Addon. Now I can open my Gimp-manipulated photos again.
Cheers
Stefan
stoffel wrote:Same problem here and yes it's the XMP Addon.
and if you install it?
stoffel
Post by stoffel »
XnView simply crashes when I select a picture which was saved using GIMP
stoffel wrote:XnView simply crashes when I select a picture which was saved using GIMP
could you send me a test file?
Anika
Post by Anika »
Same for me. With xmp.dll crash and if I rename ist to _xpm.dl no crash. You can take my http://www.bilder-hochladen.net/files/kgg9-x-182b.jpg as example.
Aybee
Post by Aybee »
Same here. Deleting or renaming XnView\AddOn\xmp.dll is a quickfix so you don't need to uninstall and reinstall xnview.
