Could not open jpg
natash
Could not open jpg
Strange problem, I could not open jpg by xnview (Error opening the file), but I could open those files using other problem. Where problem could be located?
Re: Could not open jpg
Could you upload the file or post a link to it?
natash
Strange something wrong is with the folder name, if I have files in folder NAME I could not open it, if I move it to another ie. NAME2 they are opening, but if I come back them to NAME I could not again.
Does the folder name include non-Latin, i.e. Unicode, characters? Unicode is only supported in XnViewMP and XnConVert, which you could try...
natash
You are totally right! The name contains polish letter as ż, ź, ę etc.
Thank you!
Thank you!
Please try XnViewMP, currently still in beta but under active development, which should open your images and can be used when any editing functions you need are supported.
