Crop on a slant
Hans L
Crop on a slant
Post by Hans L »
Hello:
Can you crop an image with the rectangle on a slant? (I have an image that is slanted, and if I could crop it on a slant, the image would look non-slanted :-)
Thanks,
Hans L
Re: Crop on a slant
Hans L wrote:Can you crop an image with the rectangle on a slant?
Not directly AFAIK, but you could possibly achieve a similar effect by rotating the image before cropping it?
And, if necessary, rotating it again after cropping??
Hans L
Re: Crop on a slant
Post by Hans L »
Yes, cday, but how do you rotate a few degrees?
Hans L
Re: Crop on a slant
Hans L wrote:...how do you rotate a few degrees?
In XnView Classic: Image > Rotate > Custom...
check 'Apply to image', then use the rotate slider and/or the increase/decrease buttons patiently until you obtain the rotation you need...
Hans L
Re: Crop on a slant
Post by Hans L »
Thank you, cday!
Hans L
