[bug] [batch] Variables Date (creation, modified ) fail
Arialia
Post by Arialia »
Hi, XnViewmp is great but have a problem :
Rename with variable date don't work in convert batch
I try this pattern :
{Creation Date [Y-m-d]}_#####
and have as result :
I:\Documents\My Games\Path of Exile\Screenshots\screenshot-0044.png 1904x1002x24 : chargé
F:\Temp\XN\_00001.jpg : sauvé
I:\Documents\My Games\Path of Exile\Screenshots\screenshot-0043.png 1904x1002x24 : chargé
F:\Temp\XN\_00002.jpg : sauvé
Script xbs :
<?xml version="1.0" encoding="UTF-8"?><XnView_script version="1.0" name="steampoe">
    <Output folder="F:/Temp/XN" filename="{Creation Date [Y-m-d]}_#####" case="0" format="JPEG">
        <Options overwrite="1" orgDate="true" keepMeta="true" keepICC="false" keepFolder="false" delOrg="false" multipage="false" allPages="false" openExplorer="true" clearItems="false"/>
        <JPEG quality="90" progressive="false" optimizeHuffman="false" rebuildThumb="true" orgQuality="false" DCTMethod="0" subSampling="0" smoothFactor="0"/>
    </Output>
</XnView_script>
Applications :
XnConvert Version 1.63 - windows x64 (Feb 10 2014) - Libformat version 6.55
XnViewMP Version 0.68 (May 19 2014) Libformat version 6.58
OS : Windows Seven 64bits
But in rename batch in XnViewMP it's work ....
Thanks for this program :wink:
PS : just look at the steampoe.bat generated by button 'export for nconvert' and has just
nconvert
:shock: ...
Re: [bug] [batch] Variables Date (creation, modified ) fail
See Issue 424 for current status and details.
