I would like to see the current picture number and the total number of pictures (folder or all files recursive, dependent on thumbnails selection before) in fullscreen.
This are then 2 extra variables you can select in:
settings - view - info
So you can make something like:
Picture {number} / {total number}
resulting in:
Picture 1 / 500
Is this simple possible? Maybe there are more variations by other users also wanted?
WKR,
Alex
Request: Picture 1 of 500 information displayed
Alexview
m.Th.
Re: Request: Picture 1 of 500 information displayed
I have the following info box:
{File Index} - {Filename}
{Format} - {Size KB} KB - {Width}x{Height}
({Zoom}%) - ({Tag status}) ({Rating}) ({Color label})
...which I think that's the default.
The first one - {File Index} - shows exactly this: 100/500 for the 100th picture out of 500.
m. Th.
You have the {File Index} entry in Tools > Settings... > View -- Info ?Alexview wrote:I would like to see the current picture number and the total number of pictures ... in fullscreen.
Alexview
Thanks! That's what I was looking for.
But when you use Insert >> then I don't see this as an option. Are there maybe more unlisted functions?
'File Index' does seem to be missing from the Insert options...Alexview wrote: ... when you use Insert >> then I don't see this as an option.
All the other default 'Information displayed' parameters in the above screenshot of my unmodified XnViewMP 0.68 copy 'View > Info' settings seem to be listed in Insert >> , so the omission is probably an oversight...Alexview wrote: ... Are there maybe more unlisted functions?
