Scanning with XnView - error message
Rosenholz52
Post by Rosenholz52 »
using my MultiFunctionCenter MFC-J825DW (Brother) in scan mode together with XnView (v.2.22) and high resolution (2.400 x 2.400 dpi) I get an error message (in German: see attachement): "Not enough main memory in your computer, . . . . ".
When I check the used memory it is always much below 8GB which is the provided memory (about 2,2 to 2,5 GB used, Windows 7 Prof./64).
If I want to scan anyway I have to reduce the resolution to or below 1.200 x 1.200 dpi. But in some cases I need this very high resolution. What to do??
Thanky in advance for helpful answers.
Bye, Rosenholz52
Re: Scanning with XnView - error message
Rosenholz52 wrote: ... using my MultiFunctionCenter MFC-J825DW (Brother) in scan mode together with XnView (v.2.22) and high resolution (2.400 x 2.400 dpi) I get an error message (in German: see attachement): "Not enough main memory in your computer, . . . . ".
XnView Classic is 32-bit software, could that be the reason?
In addition, the TWAIN interface in Windows is normally 32-bit even in Windows x64, so installing XnViewMP 64-bit is not certain to overcome the problem, although you could try that...
cday's answer is spot-on. This is just some additional info:
marsh ([url=http://newsgroup.xnview.com/viewtopic.php?t=23456&p=96254#p96254]Not Enough Memory[/url]) wrote:The program is a 32bit application and any of the kind have a limit which a huge jpeg and/or a panel of many thumbnails can approach. Using details view and not using preview of image might gain extra performance in some circumstances.
From post Often reported problems:
• Program crashes with high memory usage.
Exceeding 2GB for a 32bit application is a common problem on any OS. Some freeze, fail, or do nothing at the limit. Related info: Memory Limits for Windows Releases
•• To avoid: Limit size and number of thumbnails created. Limit uncompressed size of files used.
Also related:
Physical_Address_Extension
oops66 ([url=http://newsgroup.xnview.com/viewtopic.php?t=14566&p=59268#p59268]Not enough memory bug[/url]) wrote:
JohnFredC wrote:Hi Pierre
You responded (above)
So you need 464Mb to load it
... where "it" was the 47.6Mb image posted by surfacecleanerz .
That's approximately 10x the image filesize.
It's normal:
The 47.6Mbytes image is "compressed", but you need to open it (RAM memory and/or hdd swap) : 15584x7792x32bits picture = (15584x7792x4bytes)/(1024*1024)Mbytes = 463.23 Mb, then at lest 464Mb of memory.
The same file in B&W = 15584x7792x1bit = 14.47Mb
Oops, too late ! LOL
My image is LZW compressed, which should have a great affect, because 5ß% are transparent areas (because of a bug in the Panorama software...).
