Rotated Thumbnails
tonyt
Rotated Thumbnails
I have set use exif for rotation. I have rebuilt thumbnails. My JPEGS sort themselves out, but when I later return to a folder I get this. HELP!
Re: Rotated Thumbnails
lossless rebuild thumbnails?
tonyt
I have lossless set and rebuilt thumbnails - still the same???
View>Rebuild thumbnails?
tonyt
I do that and they sort themselves out, then if I leave that folder and then return to it they are upside down again!
could you send me a picture file example?tonyt wrote:I do that and they sort themselves out, then if I leave that folder and then return to it they are upside down again!
tonyt
Is the top one in this thread what you want? If not, please let me know in more detail what would help.
Thanks!
Thanks!
I think Pierre probably wants an example JPG picture file for which the thumbnail displays inverted: maximum attachment size is 1MiB so you may need to compress an example file more...xnview wrote:could you send me a picture file example?
If you have to shrink a file to reduce to file size to below 1MiB it would be as well to check that the new file exhibits the same issue with thumbnail inversion, in case resaving the file somehow clears the problem...tonyt wrote:Thanks! Will do!!!
You could alternatively send the original file as an email attachment to Pierre at the email address on the website.
tonyt
Pierre
Here is a jpeg that shows upside down as a thumbnail as per my first post. I used XNConvert to reduce from 3.7 meg. Hope thats OK?
Cheer
tony
Cheer
tony
this file is ok, please send me by mail the original file?
tonyt
Hi Pierre
Did you get my file by mail?
Cheers
Cheers
If you copy this file in another folder, you have a rotated thumbnail too??
