"This picture will beconverted to RGB with 8 bit per compone
Peter2
Post by Peter2 »
I have a multipage TIFF with these properties.
Opening the file displays this:
Why?
Peter
Re: "This picture will beconverted to RGB with 8 bit per com
Hi Peter (-:
The color space of your TIFF file is YCbCr. XnView has to convert the image to RGB in order to display it.
[url=http://www.remotesensing.org/libtiff/support.html]TIFF 6.0 Specification Coverage[/url] » Class Y for YCbCr images wrote:SamplesPerPixel = 3
BitsPerSample = <8,8,8>
PlanarConfiguration = 1, 2
Compression = 1 (none), 5 (LZW), 7 (JPEG)
PhotometricInterpretation = 6 (YCbCr)
YCbCrCoefficients, YCbCrSubsampling, YCbCrPositioning
Peter2
Post by Peter2 »
OK, thanks XnTriq
Peter
