Thank you so much!
Simple question regarding search results
merry widow
I'm sure this must be somewhere, but I can't find it. I performed a search for 16px x 16px icons/bitmaps but can't figure out how to display all 79 of the search results in one window.
It's only letting me display one at a time.
Thank you so much!
Thank you so much!
I may be frivolous but I am never trivial.
- Forum Librarian
Re: Simple question regarding search results
You have to click on the Browse button, when the search is completed.
merry widow
Because this is a large volume of images I'm going to sample I've unchecked the option for looping: The Slideshow may run once; the Slideshow may not loop. That's set and works correctly; the desired outcome however does not, and I wonder if we could just forensically review the steps I'm taking. I'm trying to keep this simple so I won't filter the file types, only their size: *.* and 16px x 16px. I begin:
mw
- Open xnview.exe
- Search for images 16px x 16px . . . (it finds 79 images)
- Click Browse
- Select All . . . (of the 79 images)
- Open Slideshow . . . (see the list of 79 images)
- Click Go
- Use the Insert Key to tag the images I want
- Now what?
mw
- Forum Librarian
Leave the slideshow dialog by clicking on Cancel and go to View » Tree pane » Categories » Tag. This will tell XnView to display only thumbnails of tagged files in the browser.
FYI: There are three buttons right above the tree pane and below the main toolbar for switching between Folders, Favourites, and Categories.
merry widow
The feature is Folders and I would respectfully suggest the Developer adopt the same convention given that it is the universally-recognized term. Since the function is what I call a "Tier 1" hierarchical operation — meaning that the operation precedes so many other functions — the developer should probably give the function its own button showing on the toolbar by default, removable if User doesn't for some reason need it.
- Forum Librarian
- Switch from view to browse mode: Ctrl+B
- Show/hide tree pane: Ctrl+Shift+F
- Show/hide tree pane buttons: View » Tree pane » Use tabs
merry widow
- Forum Librarian
Animated screenshot added to my previous post.
merry widow
XnTriq you blow my mind.
You are The Man. I of course will download it.
