Faster startup
dh7
Faster startup
Post by dh7 »
Wanted to make XnView MP to start as fast as possible. At first moved it to ram drive - helped quite a lot. And today accidentally found out that when Settings -> Integration -> "Check for program updates" is set to "Never" it starts up basically instantly.
m.Th.
Re: Faster startup
Post by m.Th. »
Yes, sure. "Check for program updates" tries to open an internet connection to see if a newer version of the program exists. This takes time.
m. Th.
dh7
Re: Faster startup
Post by dh7 »
There is the perfect quite obvious programming solution (in the XnView MP source code) so and start up is instant and updates are checked.
