Halo.
If I double-click a folder which has sub-folder, I want xnviewmp to expand the folder instead of calling rename command.
I know I can expand folder by clicking the 'arrow' icon. To me, it is much easier to double-click the folder-name because the arrow icon is so small.
Does the option for the above already exist? Where is it ?
Thanks.
double-click folder to expand; not to rename
quapurna
Re: double-click folder to expand; not to rename
strange, when i double clik on a folder name/icon, the folder is expanded, i have not rename (single click)...
quapurna
Hi, Pierre.xnview wrote:strange, when i double clik on a folder name/icon, the folder is expanded, i have not rename (single click)...
I forgot to inform that the option: General > File Operations > "Use dialog to rename file/folder" was checked/selected.
So, if I double-click the folder (in other words: click the already selected folder), the rename dialog appears.
I see that if we cancel the rename dialogue, the folder is expanded.
Anyway, I have unchecked that option and double-clicking now expands the folder properly.
Thanks.
HanVroon
Hi Pierre,
I have noticed the same behaviour.
Only if the General, File operations, Use dialog to rename file option is unchecked, folders can be expanded with doubleclick (which is what we want, I guess).
But then we miss the rename dialog for files...
Would it be possible to seperate the rename folder and rename file behaviour?
Kind regards,
Han
Kind regards,
Han
See Issue 511 for current status and details.
