Issue with "Win 7 - Display 125%"
Peter2
Post by Peter2 »
I have "Win 7 - Display 125%", and some opened files with long filenames - the tabs with the filenames are wider then my screen.
Now the "Arrow <- / ->" to scroll the tabs is nearly invisible, and after some usage it is completely gone ...
Peter
Re: Issue with "Win 7 - Display 125%"
why do you have 2 minimize/maximize/close buttons???
Peter2
Post by Peter2 »
xnview wrote:why do you have 2 minimize/maximize/close buttons???
??? - Is it not standard?
The lower one for handling the taabs (images + browser), the upper one for the entire app.
I use dual screen with Nvida Card.
Peter
it's normal sorry :)
