I attempted to open a .b16 file from PCO with XnViewMP (by double-clicking on the picture), and it did nothing.
I see that .b16 files are listed one of the 500 file types that are readable by XnViewMP.
Is there something I am missing?
I have the zip version of XnViewMP:
Version 0.69 x64 (Oct 8 2014)
Thanks,
-Andrew
XnViewMP not opening b16 file
Re: XnViewMP not opening b16 file
do you have enabled option>General>Display all file format?
adschw
Thank you, that fixed the problem.
In case anyone else is looking for it, the option is actually under:
Tools -> Settings -> General -> General -> [checkbox] Show all graphics formats.
