xcf show all layers
gershon09
xcf show all layers
Post by gershon09 »
I appreciate quite much XnView, nevertheless i have quite an issue with xcf pictures.
i need to see xcf pictures as they appear in gimp. I mean by that that i don't want to see all the layers, but only the relevant ones. Xnview shows every layers, which simply makes the pictures unviewable...
Do you know if there's a way to overcome this issue ?
Re: xcf show all layers
Please send me a sample file where some layers are not visible
Would you like XnView to display XCFs with flattened/merged layers, gershon09?
gershon09
Post by gershon09 »
Thank you both for your reply.
Sorry to answer back so late, with all the events and all in France, i forgot about my post...
Not easy for me to speak correctly in English as i'm not so good with technical vocabulary. Following pictures will explain better than any text...
First picture shows how looks the xcf file in Gimp. There are 3 layers :
Second picture shows how i wish to see the xcf picture with xnview. If In Gimp i choose not to show the second layer, then i don't want to see it with xnview:
Third one shows the picture i'm actually seeing with xnview, which i don't want:
There's a way to configure xnview to show xcf files the way i want ?
gershon09 wrote:There's a way to configure xnview to show xcf files the way i want ?
Thanks for the screenshots, gershon09.
As far as I know, there's currently no option to make XnView display only visible (i.e. exclude hidden) layers in XCF (GIMP), PSD (Photoshop) or PSP (PaintShop Pro).
gershon09
Post by gershon09 »
Ok, thank you XnTriq.
I'm quite sorry of that, but nevermind.
Xnview is an excellent viewer that i now use.
gershon09 wrote:I'm quite sorry of that, but nevermind.
There has been a similar request just the other day. Perhaps Pierre can/will implement a setting at some point.
Related topics:
please send me a xcf file
