Currently the first picture that shows is the icon for going up a directory. It seems to adhere to thumb resizing, but is a nuisance because it takes up a picture slot. Is there a way to remove these altogether? I have searched high and low but can't find a setting anywhere.
Please see attached.
Cheers
Simon
how d I remove the directory up arrow in gallery view?
sgreer
- Forum Librarian
Re: how d I remove the directory up arrow in gallery view?
Hi Simon (-:
You have to deactivate the checkbox for Parent folder ('..') in Tools » Settings... » File list » Custom filter » Used by Filter>Custom.
sgreer
Sorted! Thank you for your help
Simon
Simon
