Hi All,
I want to change the setting of xnviewMP but not sure how.
1. Whenever I open a photo from windows explorer I wish that the photo is opened in an existing window in new tab not a different window.
2. how do I show exif in each tab ?
Morad
two questions about exif and tabs
Re: two questions about exif and tabs
I think you need the following setting:eestudent wrote:1. Whenever I open a photo from windows explorer I wish that the photo is opened in an existing window in new tab not a different window.
Tools > Settings...
If I understand correctly, I think you can achieve what you want by clicking on Insert >> and selecting the parameter(s) you need:eestudent wrote:2. how do I show exif in each tab ?
Thanks for the reply.cday wrote:I think you need the following setting:eestudent wrote:1. Whenever I open a photo from windows explorer I wish that the photo is opened in an existing window in new tab not a different window.
Tools > Settings...
first option doesn't work, whenever I open a new photo a new instance is opened with single tab.
Did you get this prompt?eestudent wrote: first option doesn't work, whenever I open a new photo a new instance is opened with single tab.
If you restarted XnViewMP and still have a new instance each time I'm not sure...
