XNView Shell Extension should be integrated into XnView
klumy
Post by klumy »
XNView Shell Extension should be integrated into XnView Full distribution
It is such an useful tool !!
XNView 1.91.5
Windows XP SP3
Lesmo16
Post by Lesmo16 »
Yes, it should be integrated into distribution - 100% Support - but it shouldn't be installed automatically!
Each context menu entry needs a Registry entry. That fact, and the increased size wouldn't be favourably for an USB stick installation.
So the user should be asked during setup, if he wants to install the Shell Extension. :wink:
Everyone who believes in telekinesis, raise my hand!
Re: XNView Shell Extension should be integrated into XnView
klumy wrote:XNView Shell Extension should be integrated into XnView Full distribution
Ok, i'll add it
klumy
Post by klumy »
thank you very much !!
XNView 1.91.5
Windows XP SP3
Dreamer
Post by Dreamer »
Ok, i'll add it
But add an option to enable/disable please.
Lesmo16
Post by Lesmo16 »
Ok, i'll add it
Like suggested in the 2nd posting.
Dreamer
Post by Dreamer »
Lesmo16 wrote:
Dreamer wrote:
xnview wrote: Ok, i'll add it
Yes, but there should be also an option for "zip" version (no install).
Dreamer
Post by Dreamer »
Pierre when you plan to add it, in the next version?
BTW - you can 'close' context menu with the mouse wheel, it should be in help somewhere, if it's not there already.
