Deletes whole folder when sharp (#) in path or file name
KoTRpa
Post by KoTRpa »
When i try to delete file with # in name (or even in path to that file) XnViewMP moves whole folder to trash. Doesn't matter if option "use recycle bin" enabled or not. My OS is Ubuntu 14.04 x64. XnViewMP Version 0.72 x64 (Dec 19 2014)
Re: Deletes whole folder when sharp (#) in path or file name
You delete the file in browser?
KoTRpa
Post by KoTRpa »
Yes, in browser. But same happens even in full screen mode.
canislupus
Post by canislupus »
I can confirm this bug. I just didn’t know until now that this was because of the sharp. Same config as KoTRpa. Had this error also already in previous version. Thanks for solving.
i can't reproduce, which distribution? Do you have gvfs-trash on your system?
canislupus
xnview wrote:i can't reproduce, which distribution? Do you have gvfs-trash on your system?
Ubuntu 14.04, using gvfs-trash, XnViewMP 0.72 x64
I just reproduced it like following:
1.) Create Folder Test/#Test2 with picture squirrel.jpg
2.) Open with XnView, than delete from there this picture.
This deletes whole folder Test into bin.
I also tried with the terminal command
gvfs-trash Test/#Test2/squirrel.jpg
This works as expected and deletes just the file squirrel.jpg.
