0.72: Two issues
jadO
0.72: Two issues
Post by jadO »
Having 2 issues with 0.72:
1. Deleting files from Xnview MP explorer often results with error message that the file is in use and cannot be deleted. Same goes for move. No other programs open. Switching to Windows explorer trying to delete the file there often (not always) results in the same error message. When closing Xnview MP and deleting from Windows Explorer then it works.
2. I have directorey /A and directory /B. Both contain pictures that are categorized and rated. Now I want to change directory structure to /2014/A and /2014/B. When I move the folders into folder 2014 then all categories and ratings are lost. No matter if I move with Windows Explorer or Xnvie MP internal move. That doesn´t make sense to lose hours of work spent with rating and categorizing media files.
Re: 0.72 2 issues
jadO wrote: 1. Deleting files from Xnview MP explorer often results with error message that the file is in use and cannot be deleted. Same goes for move. No other programs open. Switching to Windows explorer trying to delete the file there often (not always) results in the same error message. When closing Xnview MP and deleting from Windows Explorer then it works.
image file?
if you use windows explorer, it's normal that categories/rating are lost. But i can't reproduce if you move in XnViewMP.
by Drag&drop?
jadO
Re: 0.72 2 issues
Post by jadO »
image file?
Video file.
xnview wrote:
jadO wrote: 2. I have directorey /A and directory /B. Both contain pictures that are categorized and rated. Now I want to change directory structure to /2014/A and /2014/B. When I move the folders into folder 2014 then all categories and ratings are lost. No matter if I move with Windows Explorer or Xnvie MP internal move. That doesn´t make sense to lose hours of work spent with rating and categorizing media files.
by Drag&drop?
For me reproducible. Seems to be a database problem.
I move /A into folder 2014 using move function in MP. Then I go to category. When I click category I see all the thumbnails. When I click thumbnails it says file not found at that location.
I restarted MP same behaviour. When I go to MP explorer on go into /2014/A I can see newly created thumbnails for the moved files but no category and rating icons.
Re: 0.72 2 issues
Video file.
'move to...' or drag&drop?
jadO
Re: 0.72 2 issues
Post by jadO »
xnview wrote:
Video file.
Video files NOT image files.
xnview wrote:
jadO wrote:
jadO wrote: I move /A into folder 2014 using move function in MP. Then I go to category. When I click category I see all the thumbnails. When I click thumbnails it says file not found at that location.
Move to.
Re: 0.72 2 issues
jadO wrote:
xnview wrote: 1. Deleting files from Xnview MP explorer often results with error message that the file is in use and cannot be deleted. Same goes for move. No other programs open. Switching to Windows explorer trying to delete the file there often (not always) results in the same error message. When closing Xnview MP and deleting from Windows Explorer then it works.
Ok, yes sometimes the video file is locked...
Move to.
are you able to reproduce it?
jadO
Re: 0.72 2 issues
Post by jadO »
Sometimes? Not possible to lets say delete 5 files altogether because one file might be locked. I would say not sometimes but 3 or 4 our of 5 a file is locked.
xnview wrote: are you able to reproduce it?
Yes. 100% reproduce.
Re: 0.72 2 issues
jadO wrote: Sometimes? Not possible to lets say delete 5 files altogether because one file might be locked. I would say not sometimes but 3 or 4 our of 5 a file is locked.
:( could you ty 0.75 and tell me if you have always the problem with video files?
i can't preproduce :( which windows version?
Could you try with Ctrl+X/Ctrl+V?
jadO
Re: 0.72 2 issues
Post by jadO »
Unfortunately same issue with 0.75.
This is annoying as moving files does not work as well. Moving results in a new file with new timestamps in destination folder and XnViewMP cannot delete the source file.
Edit: Ctrl+X/Ctrl+V works. So it should be possible to solve the issue.
Re: 0.72 2 issues
jadO wrote: Unfortunately same issue with 0.75.
Issue 1 or 2?
jadO
Re: 0.72 2 issues
Post by jadO »
Issue 1 or 2?
Issue 1. As said: Deleting does not work as files is in use and moving does not work. The destination file gets created but the source file cannot get deleted.
Re: 0.72 2 issues
jadO wrote: Issue 1. As said: Deleting does not work as files is in use and moving does not work. The destination file gets created but the source file cannot get deleted.
Do you have a way to reproduce this issue?
jadO
Re: 0.72 2 issues
Post by jadO »
I am currently on 0.75 and same issue. For me it is almost 100% reproducible. Whenever I want to move a video file or delete it then I get these problems.
Re: 0.72 2 issues
jadO wrote: I am currently on 0.75 and same issue. For me it is almost 100% reproducible. Whenever I want to move a video file or delete it then I get these problems.
so moving a video file with mouse is a problem, Ctrl+X/Ctrl+V works, right?
jadO
Re: 0.72 2 issues
Post by jadO »
Yes.
